Error to Add New PID to OBD-II Uart Adapter
rDeveloper
Post by rDeveloper »
Im testing the "OBD2 adapter" and with the "rpm_led_uart" sketch work ok.
I added other Pid as PID_ENGINE_LOAD, PID_INTAKE_MAP , that reads the data, but if i add some PID´s as ENGINE_TORQUE_DEMANDED, PID_FUEL_PRESSURE, don´t it read and the reading the other PID is slows.
Is it possible that "OBD2 adapter" can´t read all Pid's in all cars?
Thank you very much
Re: Error to Add New PID to OBD-II Uart Adapter
That's mostly because your car is not responding to requests of those PIDs.
onche
Post by onche »
Hello, si it means that we cannot get those PIDs even if they are standard ? Is there a way to find it ? I need the torque :evil:
cheers
