Today I have received the Freematics OBD-II Emulator MK2 and also the Freematics ONE+. How I want to connect with the "Freematics ONE+" I have bought the tool "https://www.obdautodoctor.com". My problem is that not get a connection between the "Freematics ONE+" and the SW "obdautodoctor". I have tested the Bluetooth connection and serial, but in both the problem is the same "Failed to connect".
Have you test the tools "obdautodoctor" with the Freematics ONE+" ?
Can you tell me a tools that work correctly with the Freematics ONE+?. My idea is to use the Frematic Emulador 1.0.9 to change the values of " Freematics OBD-II Emulator MK2" and by the other hand, I want to verified this change with a tools, in my case I had prepared the "obdautodoctor".
Please, I hope yours answer.
Regards.
Connection betweend the Freematics ONE+ and obdautodoctor
Re: Connection betweend the Freematics ONE+ and obdautodoctor
Freematics ONE+ is not a ELM327 bluetooth OBD dongle which OBD Auto Doctor works with.
