Problem with telelogger
renegade1
Post by renegade1 »
Telelogger is not working for me I get this
#OBD....NO
#MEMS...OK
#GPS...OK
#GSM...OK
#GPRS...OK
#HTTP............
or
#OBD...NO
#MEMS...OK
#GPS...NO
#GSM...OK
#GPRS(APN:airtelwap.es)...OK
#HTTP.................
And keeps connecting for ever
if i use this command
AT+CREG?
I get
+CREG: 0,2 <---: still searching for an operator to register to
Which is valid for the telelogger code and then jumps to the HTTP part and loops forever
Im using vodafone chip in Spain, which works on mobile phone . PIN is not set for this SIM
Any ideas?
jarii
Re: Problem with telelogger
Post by jarii »
I have this same problem, did you get this solved?
Signal issue. Check CSQ value.
rdotlee
Post by rdotlee »
Anyone have a working version of telelogger that's available for debug over USB?
