I am using Freematics ONE.
Occasionally, fields are shifted down by one. For example, the date is saved in the time field, the time field is saved in the latitude field, and so on, as follows:
14 11 0
0 10 190517
0 A 11230640
0 B 40440093
Any idea what would cause this and/or how to solve it?
Data shifted down one row
Re: Data shifted down one row
Please let me know if I can provide any information that would help to diagnose this problem.
This happened when the logger was plugged into a 2015 Chrysler 200C. Maybe I'll try it on a different car.
Also, it happens at varying intervals (between 10 and 30 seconds). When it happens, the longitude value is bogus (but the value is shifted down by one). For example, longitude values when this happened are -32506, -32490, -32491, and - 32492 (these are in correct sequence so perhaps the order for last 3 numbers is just a coincidence).
