Freematics One+ Traccar - server change
gersonlourenco
Post by gersonlourenco »
Friends, I purchased a Freematics ONE+ Traccar that is already working perfectly in my car. Now I would like to change the Traccar server from demo.traccar.org to server.traccar.org, as I acquired a tracking account. How should I proceed ?
Re: Freematics One+ Traccar - server change
You need to build and upload your own firmware to the device. The code of the firmware is named telelogger in the github. The easiest way is using Freematics Builder with gives you a GUI to configure the build on which you can change the server URL and port. If you are comfortable to use Visual Studio Code, following is a configuration guide from traccar.
https://www.traccar.org/freematics-configuration/
