Page 1 of 2
ISO 9141-2
Posted: Mon Jan 26, 2015 5:19 pm
by aslak
Has anyone been able to get out other data than RPM and SPEED, from the ISO 9141-2 protocol? If yes, could you post an example of your code?
That'd be great - thanks!
-Aslak
Re: ISO 9141-2
Posted: Tue Apr 07, 2015 9:46 am
by lbroph
I just received my OBD-II adapter for arduino and I am having issues initializing.
Car: 2001 Saab 9-3
Protocol: ISO 9141-2
Arduino: RoboRED (UNO)
I cannot even get the example RPM sketch to work. It doesn't seem to connect to the car. Used oscilloscope to verify arduino is transmitting, downloaded and added libraries successfully.
I can compile and upload the example code to my UNO just fine (no errors). After uploading, Rx light blinks about once/3 seconds if i keep the UNO connected to the computer. Once I disconnect and use other power source (from OBD-II adapter) it doesn't blink anymore, but scope shows it is still transmitting.
****** Does anyone have this same problem or the solution to it??? *******
Below is the example code I tried.
* Distributed under GPL v2.0
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
COBD obd;
void setup()
pinMode(13, OUTPUT);
obd.begin();
while (!obd.init());
void loop()
int value;
digitalWrite(13, value > 3000 ? HIGH : LOW);
Re: ISO 9141-2
Posted: Tue Apr 07, 2015 10:13 pm
by lbroph
Car: 2001 Saab 9-3
Arduino: Uno (RoboRED)
Problem: Adapter will not initialize
Question: Do I have to modify the example (RPM) code for my given protocol (ISO 9141-2)? Does the adapter try all protocols when trying to initialize (obd.begin())?
Re: ISO 9141-2
Posted: Mon Apr 20, 2015 10:42 am
ISO 9141-2 is actually not supported though it's declared in the OBD.h.
Re: ISO 9141-2
Posted: Thu Oct 13, 2016 10:37 pm
by matyzs
Is exist another adapter that supports protocol ISO 9141-2 please? (sorry for my english )
Re: ISO 9141-2
Posted: Fri Oct 28, 2016 8:26 pm
Many cheap ELM327 (or cloned ones) support ISO 9141-2. We just don't have time and motivation to improve our implementation since the protocol is used by fewer and fewer cars.
Re: ISO 9141-2
Posted: Sat Oct 29, 2016 5:03 pm
by nemesis
Hi is it possible add iso9142-2 protocol in the library? here is explained the difference of response
http://www.instructables.com/id/Low-Cos ... /?ALLSTEPS
Re: ISO 9141-2
Posted: Wed Jan 23, 2019 10:31 pm
by jolacoupe
2 years later still no upgrade to get the OBD UART to work with ISO 9141-2 ?
It would be a great idea to get motivations because newer cars have a very rich dash bord unless the old cars are more interesting for ARDUINO OBD projects.
Regards
Re: ISO 9141-2
Posted: Wed Aug 28, 2019 11:50 pm
by fifapro23
I would also like to see updates regarding this. Looking to make a digital gauge cluster for my 99 miata. Stanley, any help on this would be much appreciated.
Re: ISO 9141-2
Posted: Thu Sep 12, 2019 5:17 pm
Sorry to disappoint you but we will not spend any time on the support for any pre OBD-II era vehicles.
