STM32F103C8T6 Programming
James Shim
Post by James Shim »
I am a new people in this project. My question is if we need any firmware programming for this chipset. Or does the ATMEGA chipset take OBD-II data from it?
Re: STM32F103C8T6 Programming
You only need Arduino programming.
Marek
Post by Marek »
Is it possible to access the stm32 firmware in order to reprogram it for use with pwmj1850
I would *only* need pwmj1850
Sorry j1850 can't be supported. It's not about upgrading firmware.
Marek
Post by Marek »
it seems the atmega chip has got everything needed in order to implement both j1850pwm and j1850vpw what is the actual problem in not supporting these protocols?
Marek
Post by Marek »
I found a 10-pin header inside the datalogger - is it the 10-pin header for the STM32 chip?
ankostis
Post by ankostis »
For the interest of those landing here, J1850 pins 2/10 are not even connected to any ICs in the freematics ONE+ B/H.
Correct?
But in general, these standards are deprecated, and newer cars don't even support them; the focus is on ISO 15765, pins 6/14 (including ISO 14229-3 for UDS), correct?
Neither model B or model H supports J1850.
