Hello.
We are using the latest versions of the GUI and firmware (1.0.8). After attaching an OBD device to the emulator, we try to set a few DTC codes with the GUI, by typing the number and pressing the "Mode 03" button. A message pops-up that the code is set, but later when we read the DTC codes of the device, it says there are none set. Our part of the software works correctly, since when using the OBD with a car, we get DTC codes. What reasons could there be, that we can't read the DTCs set by the Freematics Emulator?
Thank you.
