Can I monitor the voltage if vehicle is parked?
MaxG
Post by MaxG »
Firstly, what a great product; and very affordable too ... nice work!
I have an OBD II port in my car, which has a permanent voltage while the car is switch off.
I also noticed when I parked the car for 4 weeks over the Xmas period that the battery went flat. (It is a new battery; I left the car unlocked, and suspect either the keyless go, or vehicle's CAN modules to slowly drain the battery slowly to the point that it won't start the car).
Interested in the Freematics 'dongle' in principle, and wanting to monitor the Voltage of the parked car, I was wondering, whether the Freematics OBD readers only work, when the ignition is on, or also when the vehicle is parked (ignition off) -- car locked or unlocked?
Any hints appreciated.
Re: Can I monitor the voltage if vehicle is parked?
Yes it can monitor the voltage even the ignition key is off.
rads1342
Post by rads1342 »
Hi MAx G...
Am interested in what you described...
Did the Data Logger capture any parasitic load that was within your vehicle while the engine was not running?
Regards
rapidcarremoval
Post by rapidcarremoval »
I am interested in this dongle too if it can really monitor the voltage of a parked vehicle, ignition off. I am having the same issue with my car and got my battery replaced already but I think it still has the same problem. Maybe I will give this a try before I sell my car.
ronaldo121
Contact:
Post by ronaldo121 »
sounds interesting!
wladkolc
Post by wladkolc »
hi..anybody resolved this? i want to monitor parked vehicle too.
