Set VIN on Emulator MK2
mattie47
Post by mattie47 »
I've been using the Freematics Emulator MK2 for a wee while now and keep running into issues with setting the VIN.
My device plugged into the Emulator more often than not picks up A1JC5444R7252367 as the VIN, despite me setting it either in the Windows GUI, or through AT commands.
I'm also trying to set this pragmatically, yet don't even get the VIN printed out:
AT SET VIN=12345678912345678
AT GET 0902 <--- PID for VIN Req.
0902=01 05 <-- Don't understand why this is the response.
How can I correctly set the VIN, and also confirm it is set correctly ?
Side question:
When you boot up the Emulator, is it required to set ATVIN1 as well, if so, before or after above? It's unclear what the actual out-of-the-box default values are when Emulator is plugged in, and I haven't been able to find any docs on this.
Thanks,
Matt
