Sending information to MK2 emulator from sensors
Johnybeas
Post by Johnybeas »
Ok guys, so I've been searching like crazy. I can't find info pertaining to what I want to do. In the listing it states "The 6-pin XH-2.54 socket provides an interface for serial TTL connection as well as DC power supply of 3 different voltages. This makes it possible for a micro-controller board like Arduino to control the emulator with some source of data (e.g. sensors)".
What I'm trying to do is to send info to the port from my racecar (obd1 car with complete custom wiring harness) that has a stand alone ECU that has CAN high low output and different PID's etc. I want to get info into an OBD2 port so I can use Bluetooth OBD2 reader to interface with torque Android app. Any help as to hardware needed and guidance as to where to learn how to wore this properly would be very much appreciated.
Thanks in advance!
