Noob here.. UART 2.1 and Arduino Uno - Serial Garbage on Example Sketch
jimmyw91
Post by jimmyw91 »
Thank you for taking a moment to try and help me out, any feedback is appreciated.
I am trying to make use of my UART 2.1 adapter. I started by downloading the libraries from github and attempting to run the example sketches. I uploaded the sketches and did not have luck with any of them. The two examples that included serial data I see garbage in the serial monitor. I have included a photo so you can see how I have it set up, what sketch is running and what the serial monitor spits out:
https://imgur.com/83dGK5d
This is the wiring to the Arduino, nothing special to see here (unless I did something extra dumb...). I get the same garbage output whether the obd2 adapter is connected to my car or not.
https://imgur.com/5gMnkLz
Re: Noob here.. UART 2.1 and Arduino Uno - Serial Garbage on Example Sketch
Do you know Arduino UNO's Serial and serial monitor are one thing? The adapter uses Serial and that means you should either not use USB monitor or use a Arduino Mega.
