HowTo get hardware configuration from One+
Posted: Fri Oct 01, 2021 12:28 am
by gessi
I purchased the "Freematics ONE+ Traccar Edition" with product ID "F1P-T" and got it reconfigured to be used by a traccar server (subscription one which works fine with another device) using the configurator.
SIM7600 is properly configured as I can see the Freematics device connecting to the traccar server but there is zero GPS/GNSS data received. I should have purchased the internal GNSS antenna but would like to find a way to troubleshoot the GPS issues and get the hardware information from the device.
Currently not connected to ODB in my car but using power from a Micro-USB power adapter.
Re: HowTo get hardware configuration from One+
Posted: Fri Oct 01, 2021 11:28 am
Did you use Freematics Builder? Make sure after loading telelogger, you choose the correct type of GNSS. There are 3 options, internal, external and cellular. Also make sure to change CPU clock to 160Mhz.
