MEMS Sensor dead??
Posted: Sun Nov 28, 2021 10:59 pm
by etv99
I just bought the Freematics ONE+ Traccar and I figured out, that my adapter is not waking up when the car is moved.
When flashing the image for data transmission to the freematics hub, I get there no acceleration data when shaking the adapter...
I'm using the telelogger.ino in firmware_v5
...btw, YES it's enabled in config ;)
and yes I'm using the latest files from github https://github.com/stanleyhuangyc/Freematics
what can I try?
Tom
device ID: E591GJ0A
Re: MEMS Sensor dead??
Posted: Mon Nov 29, 2021 1:36 pm
Please check serial output. Do you have MEMS:OK or MEMS:NO. Note that data is submitted to server once a second and you may not be able to see instant data change from web page.
Posted: Mon Nov 29, 2021 6:20 pm
by etv99
thanks for your reply!
I get MEMS in the serial Output.
I tried again with my traccar setup (only changed the server) and now I get the values again!
But my connector would not come back from sleepmode when I "shake my car". I have set the wakeup level down to 0,1 but have no wakeup.
Also when I start the car there is no wakeup.
Battery without ignition/motor off is 12,8 V, with on it's over 14 V.
thanks
Tom
Posted: Fri Dec 03, 2021 8:28 pm
Have you checked serial output when ignition started?
