Use case question for correct product
undeadghost
Post by undeadghost »
I tried contacting multiple times through the store contact form and another email I found, but was not successful in getting a response so I figured I try here.
I'm looking to purchase a Freematics one but wanted some clarifications on its features. Am I able to program it to do the following:
1. Device plugged in vehicle OBD2 port continuously to monitor for codes.
2. When it detects a specific subset of codes, clear it automatically
3. Any codes not within that specific subset will still behave normally and trigger the CEL/other lights in the dashboard.
If it has the capability for this feature, I will make the order. Or if this specific product can't, but another product that you have can, then please let me know about that as well. Thank you!
Re: Use case question for correct product
You need to write your own code. Please note not powertrain related codes can be read.
undeadghost
stanley wrote: Thu Aug 25, 2022 9:33 am You need to write your own code. Please note not powertrain related codes can be read.
Yes, I understand I need to write my own code. However, my question is, does the Freematics One have that capability? Or do I need another product instead? Does the Freematics One have the capability of reading and clearing diagnostic codes (for my use-case specifically, cat specific error codes/P-Codes like 420/430/3270/3271)?
Thanks!
