SIM5360 don't acces to my server
platoon
Post by platoon »
Since I get a Freelatics One+, I try the code sample and config on your github (https://github.com/stanleyhuangyc/Freem ... im5360test)
for made a connectivity test with my M2M card (I have a valid APN), it work well :
Serial port COM6 opened at baudrate of 115200bps
ATI
Manufacturer: SIMCOM INCORPORATED
Model: SIMCOM_SIM5360E
Revision: SIM5360E_V3.5
IMEI: 863789026678940
+GCAP: +CGS
Connecting network..........OK
Operator:Mobistar
Obtaining IP address...XXXXX
CSQ:5.0dB
Init UDP...OK
Init HTTP...OK
Sending UDP datagram...OK
Connecting...
Sending HTTP request...OK
Receiving...failed
Waiting 3 seconds...
Connecting...
Receiving...OK
-----HTTP RESPONSE-----
HTTP/1.1 200 OK
Server: nginx/1.10.3 (Ubuntu)
Date: Fri, 08 Jun 2018 09:50:17 GMT
Content-Length: 46
Connection: keep-alive
Expires: Sat, 09 Jun 2018 09:50:17 GMT
Cache-Control: max-age=86400
{"date":180608,"time":95017,"tick":3738027467}
Serial port closed
But If I change the adress / port it doesn't work anymore :
START
ATI
Connecting network...........OK
Operator:Mobistar
Obtaining IP address...XXXXXXXX
CSQ:5.0dB
Init UDP...OK
Init HTTP...OK
Connecting...
AT+CHTTPACT="www.lsres.net",80
Error connecting
+CHTTPACT: 227
ERROR
I have try some websites with HTTP POST request like http://XXXX:38080/BEG/freematic/gps
This website have an "Authorization: Basic"
The code stop working on the code :
if (!net.httpConnect()) {
Serial.println("Error connecting");
Serial.println(net.buffer);
errors++;
return;
And it's return this error
Error connecting
+CHTTPACT: 227
Do you have any idea how is the problem ?
I have try the commands
- AT+CHTTPSOPSE
- AT+CHTTPACT
But it's not working in https or http
fwh
Re: SIM5360 don't acces to my server
Post by fwh »
In linux, I'd recommend man in the middle'ing it with socat:
socat -v TCP-LISTEN:38088 ,forever,reuseaddr,fork TCP:http://XXXX:38080
and then change the port that you're accessing the server to 38088. That socat command will show all data flowing back and forth between the client and the server on port 38088.
