i just bought a one+ and was looking forward to using with a custom audi motronic data logging protocol but im new to this so im not sure how to make the one + watch for the data. my ultimate goal is to either record to SD card or push the data over bluetooth to an android app.
the output from the ECU is rather simple. it sends 0xAA 0xBB than it starts sending data from the ECU's RAM and when it starts over at the beginning it sends 0xAA 0xBB again. this is running the moment the key is on regardless weather anything is watching or not.
the data being recorded from the driver that was made by another person to be used with a program called winlog. i modified this driver to have US based units of measure and be able to monitor wideband AFR controller through the ECU as well. Over all i dont know where to start to make this work but i know it can work. any help would be greatly appreciated. thanks!
// Calculates and sets data
void setData(unsigned char* buf, int len) {
// Boost chip
fielddata[0] = buf[0]/194.0*100; //N75
fielddata[1] = buf[1]/194.0*100; //N75 base
fielddata[2] = (buf[2] / 255.0 * 5 / 1.03515625*config.mapMult + config.mapOffset)*0.14503773800722 - 14.6959494; //PSI
fielddata[3] = buf[2] / 255.0 * 5 / 1.03515625*config.mapMult + config.mapOffset; //MAP
fielddata[4] = (buf[3] / 255.0 * 5 / 1.03515625*config.mapMult + config.mapOffset)*0.14503773800722 - 14.6959494; //PSI REQ
fielddata[5] = buf[3] / 255.0 * 5 / 1.03515625*config.mapMult + config.mapOffset; //MAP REQ
fielddata[6] = buf[4]*0.5; // KNOCK1
fielddata[7] = buf[5]*0.5; // KNOCK2
fielddata[8] = buf[6]*0.5; // KNOCK3
fielddata[9] = buf[7]*0.5; // KNOCK4
fielddata[10] = buf[8]*0.5; // KNOCK5
fielddata[11] = buf[9]*0.5; // KNOCKGLOB
fielddata[12] = buf[10]*0.5; // KNOCKDYN
// Fuel chip
fielddata[13] = (buf[31])*40; //RPM
fielddata[14] = (buf[30]*256+buf[29])/25.0; //LOAD
fielddata[15] = (buf[28])*0.068; //Battery voltage
fielddata[16] = (((buf[27])-70.0)*0.70)*9/5+32; //IAT (F)
fielddata[17] = (((buf[27])-70.0)*0.70); //IAT (C)
fielddata[18] = (((buf[26])-70.0)*0.70)*9/5+32; //ECT (F)
fielddata[19] = (((buf[26])-70.0)*0.70); //ECT (C)
fielddata[20] = (buf[25])*0.416; //TPS
fielddata[21] = 0.75*((buf[24])-(buf[23])); //Timing request
double ipw = 0.52*((buf[22]) + (buf[21])/256.0);
fielddata[22] = ipw; //IPW (effective)
fielddata[23] = (buf[20])*0.010667; // Injector dead time
fielddata[24] = ipw + fielddata[23]; // IPW (actual)
fielddata[25] = fielddata[24]*fielddata[13]/1200.0; // IDC
fielddata[26] = (((buf[19]*2)/1.609344)-0.621371)-2; //VSS MPH
fielddata[27] = buf[19]*2; //VSS KMH
fielddata[28] = ((buf[18]*0.0196078)-0.4)*2 +10; //Zetronix Wideband input
fielddata[29] = buf[17]; //MAF table cell
// Target AFR
double calcvalue = (buf[15]*256+buf[14])*pow(2.0, buf[13]);
unsigned char injconstant = buf[16] == 0 ? 1 : buf[16];
calcvalue = (128.0/injconstant)*calcvalue;
calcvalue = calcvalue == 0 ? 1 : calcvalue;
calcvalue = 1/(calcvalue/65536.0)*14.7;
fielddata[30] = calcvalue > 99.0 ? 99.00 : calcvalue;
// Knock including DYN and GLOB
fielddata[31] = fielddata[6] + fielddata[11] + fielddata[12]; // KNOCKOUT1
fielddata[32] = fielddata[7] + fielddata[11] + fielddata[12]; // KNOCKOUT2
fielddata[33] = fielddata[8] + fielddata[11] + fielddata[12]; // KNOCKOUT3
fielddata[34] = fielddata[9] + fielddata[11] + fielddata[12]; // KNOCKOUT4
fielddata[35] = fielddata[10] + fielddata[11] + fielddata[12]; // KNOCKOUT5
fielddata[36] = (fielddata[31] + fielddata[32] + fielddata[33] + fielddata[34] + fielddata[35])/5; // KNOCKOUTAVG
// Ignition angle output
fielddata[37] = fielddata[21] - fielddata[31]; //IGNOUT1
fielddata[38] = fielddata[21] - fielddata[32]; //IGNOUT2
fielddata[39] = fielddata[21] - fielddata[33]; //IGNOUT3
fielddata[40] = fielddata[21] - fielddata[34]; //IGNOUT4
fielddata[41] = fielddata[21] - fielddata[35]; //IGNOUT5
Using one+ with custom data logging protocol
Re: Using one+ with custom data logging protocol
no one can help with this?
So i started working on this to figure it out. im not using GPS so i patched a wire from pin 7 of the OBD connector to the RX pin for the GPS receiver thats connected to the ESP32's GPIO32 pin. now with the basic sketch i made i get the raw data coming from the ECU's K-line on pin 7 with the key on and the car not running. as soon as i start the car my data flow turns to all 0xFF hex and is no longer consistent. im not sure what is causing this. Im thinking about trying to use the xbee pin TX to ESP32 GPIO16 and see if i get the same result. i think im getting some sort of feedback from STM32.
i tried to post the last sketch that semi worked but the forum wont let me.
Who is online
Users browsing this forum: No registered users and 1 guest
