Did anyone manage to make freematics One+ send data to NodeJs server via HTTP POST
mcfreematics
Post by mcfreematics »
Did anyone manage to make freematics One+ send data to NodeJs server using PROTOCOL_HTTP_POST ?
Do you know where to set the content-type ? Do we need to define a global variable in the config.h
#define HTTPFILETYPE_JSON "application/json"
is the "application/json" the right type ? or is it "text/plain" or something else ?
Context/further details:
sending data (GPS/OBD) to hub.freematics.com works fine thru PROTOCOL_UDP.
Now I need to send the same data to a NodeJs backend via HTTP post.
Any help/hint is much appreciated.
ticcoid
Re: Did anyone manage to make freematics One+ send data to NodeJs server via HTTP POST
Post by ticcoid »
I would be interested as well. Couldn't get it working :(
daveywatt
Post by daveywatt »
Did you guys ever get this working? I am seeing HTTP issues over SIM7600 but over WiFi its fine.
aanter1989
Post by aanter1989 »
The answer to this question is even harder than choosing leggings vs yoga pants. I think that the answer to this question is known more at technical support.
cmendes0101
Post by cmendes0101 »
Have you guys tried the newest commits in Github? I was having the same issue but getting the new updates with rebuilding libs is working.
It was on another thread: viewtopic.php?f=9&t=44144
