Odometer PID
Discussion about Data2KML and other open-source telematics utilities developed by us
sseaton
Odometer PID
Postby sseaton » Mon Sep 11, 2017 2:48 am
Has anyone been successful in finding a PID to READ the vehicle Odometer/Mileage?
I have looked over the OBD2 docs and have not seen anything. There are plenty of scan-tools out there that read the Odometer so it must be available somehow. Does anyone have any insight on this?
vasilis
Re: Odometer PID
Postby vasilis » Thu Feb 01, 2018 8:32 am
I want the same information so I was googling around.
Based on my research this is not an OBD PID and each manufacturer might have a custom code for it.
It seems we have two realistic options (the third is paying a lot of money pay the manufacturers for their codes):
1) Reverse engineer and figure out the code for a specific vehicle
2) Manually add your vehicles current milage and then use the OBDII PID that tells you how many kilometer the car has done since the last error code reset to keep track thereafter
If you find anything else out please do share!
vk5bd
Re: Odometer PID
Postby vk5bd » Fri Feb 02, 2018 10:59 am
With the limited information that seems to be available, I would think using the PID_DISTANCE_WITH_MIL is your best bet for now, You would need to know the distance at which the fault codes where cleared and then add that to the read value, ie PID_DISTANCE_WITH_MIL + Offset
