LCD display only 1st caracter per lcd.print command
Discussion about software developed by Freematics, including Freematics Hub, Freematics Builder, Freematics Emulator GUI
olivier
Postby olivier » Thu May 26, 2016 1:52 am
I try to reactivate a OBD KIT (Arduino OBD-II Telematics Kit #3 ) that I purchase 2 years ago, with the original libraries and software, but the lcd displays only 1 caracter per line. Since then, I think that the only change is the Arduino IDE (1.6.7).
Is there a way to make it working?
Thanks.
kumakiri
Re: LCD display only 1st caracter per lcd.print command
Postby kumakiri » Thu Dec 08, 2016 12:26 pm
You will have to modify the Arduino library to make it suitable for multi-line.
~\Arduino\libraries\MultiLCD\R61581.cpp:
size_t LCD_R61581::write(uint8_t c)
return 1;
++ add last line "return 1;"
~Arduino\hardware\arduino\avr\cores\arduino\Print.cpp:
size_t Print::println(void)
return write('\r') + write('\n');
++ renew "return write("\r\n");"
for further information, see http://forum.arduino.cc/index.php?topic ... msg2921626
Return to “Freematics Software”
Who is online
Users browsing this forum: No registered users and 4 guests
