Ignition on/off on OBD-II emulator
Bonadio
Post by Bonadio »
Hello
I just bought the OBD-II emulator and my application goes to sleep when the ignition is off and should restart when ignition is on again. I saw in the documentation (https://freematics.com/pages/products/f ... mmand-set/) that the pins does NOT reflect the voltage, but the ignition OFF part is working and the pins DO reflect that.
Does the ignition ON part should work?
