DTC codes aren't P0xxx.
protomor
Postby protomor » Mon Feb 20, 2017 6:50 am
So the code I have to consume Stanley's DTC read is:
unsigned int numberofcodes = obd.getDTCCount();
lcd.println(numberofcodes);
if (numberofcodes > 0)
uint16_t codes[8];
byte dtcCount = obd.readDTC(codes, numberofcodes);
if (dtcCount == 0) {
lcd.println("No DTC");
else
for (byte i = 0; i < numberofcodes; i++)
lcd.println(codes[i]);
But I get 20484 and 16896 instead of the P codes. How do I convert this into one of the P codes?
protomor
Re: DTC codes aren't P0xxx.
Postby protomor » Sat Feb 25, 2017 12:28 pm
Staaaaaanleeeeeeeey HAAALP!
Postby stanley » Wed Mar 15, 2017 11:54 am
Convert it to HEX.
Serial.println(code[i], HEX);
There is no P as all readable codes are for P (powertrain).
protomor
Postby protomor » Wed Mar 15, 2017 10:13 pm
I thought I tried that but I'll give it another go.
vishwanath
Postby vishwanath » Fri Feb 15, 2019 1:31 am
I too face the similar issue reading the DTCs.
On converting to hex I got 100, 200, 300, 4300, 8200, c1 . I got 100,200,300 but how to match with 4300 and 8200 and c1
here is the my piece of code:
char* getDTC() {
uint16_t dtc[7] = {0};
static char dtcbuffer[100] = {0};
char dtc_codes[50] = {0};
int dtcCount = obd->readDTC(dtc, 7);
if (dtcCount > 0) {
Serial.print("DTC:");
Serial.println(dtcCount);
//Serial.print("Error codes are: ");
for (byte n = 0; n < dtcCount; n++) {
Serial.print(dtc[n],HEX);
Serial.print(", ");
sprintf(dtc_codes + strlen(dtc_codes), "%x, ", (dtc[n]));
//obd->clearDTC();
sprintf(dtcbuffer, "DTC:{%s} ", dtc_codes);
return dtcbuffer;
Can you please help me in getting all the DTCs and also to right way of matching the codes?
tompage12
Contact:
Postby tompage12 » Tue Apr 16, 2019 9:57 pm
Thanks for sharing such useful ideas.
alankroenlein
Postby alankroenlein » Sat Dec 07, 2019 7:12 pm
The readDTC function does a hex2uint16 conversion in the body of the code. I am getting a fault code of 770, which seems a bit unlikely since my car has a manual transmission. Any thoughts on how to interpret this output? Can anyone confirm that the fault codes of this function are indeed being returned as integers? 0x770 would be 302 in decimal, which would indicate a cylinder misfire. This seems more likely, but seems wrong from the way the code is written. Any help on this?
Alan
MartinaLebel
Postby MartinaLebel » Thu Jan 09, 2020 8:18 am
Thanks for ideas. Nice!
wbmsmart
Postby wbmsmart » Thu Feb 13, 2020 10:04 am
A DTC code is a series of diagnostic trouble codes used by a vehicle's onboard diagnostics (OBD) system to alert you when a vehicle experiences a malfunction. These codes were created by the Society of Automotive Engineers (SAE) to help vehicles comply with emission regulations.
Users browsing this forum: Baidu [Spider] and 6 guests
