One+ Model B Cellular
darky83
Post by darky83 »
Hi all,
Having some trouble getting my Freematics One+ Model B Traccar edition working stable.
The SIM card is tested and working fine so there is no trouble there.
the same SIM card has worked before in the One+ but it has never been stable for me somehow when connected to the OBD port it sometimes sends data but most of the times it won't.
SIM card is entered correctly (double checked a few times now) but it just does not seem to detect the cellular module 90% of the time.
Sometimes it works and it than detects the IMEI number of the simcard but most of the time it just shows:
CELL:NO
CELL OFF
Tried building from Freematics builder and from Visual Studio Code but no change there (as expected) and grabbed the latest git version a few times already.
When it is working the devices sends data (mostly after power has been off for a while) and it shows the module than in Freematics builder as:
SIM7600E-H IMEI:xxxxxxxx
But when power is disconnected from the devices after that in 90% of the time it will not detect the cellular again.
Any troubleshooting tips or suggestions of what is going on? (or do I just have a faulty module maybe?).
Re: One+ Model B Cellular
This issue was just fixed in the recent update of the library. Please re-compile telelogger with the latest library from github to solve this.
darky83
Post by darky83 »
Tried it but sadly no change still most of the times it won't detect the module.
Grabbed the latest commit from https://github.com/stanleyhuangyc/Freematics
(d888de2 as of now) recompiled the library's but still sadly the same issue.
Some logging shows: (used <SNIP> to remove default GPS data logging that it shows)
CPU:240MHz FLASH:4MB
IRAM:359KB PSRAM:8191KB
DEVICE ID:XXXXX
TYPE:14
MEMS:ICM-20948
ACC BIAS:-0.00/-0.05/1.01
GNSS:OK
OBD:NO
SD:1936 MB total, 1 MB used
/DATA/1.CSV
<SNIP>
File: /DATA/44.CSV
[GPS] XXX 0km/h SATS:8 Course:0 2021-05-17T19:47:41.700Z
[BUF] 12 samples | 80 bytes | 3%
<SNIP>
CELL:NO
<SNIP>
CELL OFF
<SNIP>
CELL:NO
<SNIP>
CELL OFF
<SNIP>
Stationary for 180 secs
STANDBY
ACC BIAS:-0.01/-0.06/1.01
CELL:SIM7600E-H
IMEI:xxxxxxxxx
Wakeup
ACC BIAS:0.00/-0.15/0.99
CELL OFF
OBD:NO
/DATA/1.CSV
<SNIP>
CELL:NO
CELL OFF
and after letting it off for a while it shows:
DEVICE ID:xxxxxx
TYPE:14
MEMS:ICM-20948
ACC BIAS:0.04/-0.18/0.99
GNSS:OK
OBD:NO
NO SD CARD
CELL:SIM7600E-H
IMEI:xxxxx
<SNIP>
CELL OFF
(Yes also removed SD card for testing in this case)
screenshot freematicsbuilder
dfritz
Post by dfritz »
Unfortunately, I continue to have problems with the device. It feels like it runs better after the new compile, but not perfect. I have a lot of dropouts on the trips and sometimes enormous jumps on the map that you can not use the information properly. I have also seen that the device continues to switch to standby in the meantime. The Libs are the latest, I have the Libs again recompiled.
I must admit the telelogger source code is not perfect and you are welcome to contribute your improvements.
darky83
Post by darky83 »
As a novice programmer probably won't be that much of a help :) but trying where possible.
Just tried the firmware_v5\sim7600test and this one seems to have the same instability:
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Init cellular module...SIM7600E-H OK
IMEI:XXXXXXXXXXXXXXXXXX
SIM Card OK
Registering on network...NO
Init cellular module...NO
IMEI:XXXXXXXXXXXX
SIM Card OK
Registering on network...OK
Operator:XXXXXXXXX
Obtaining IP address...xx.xx.xx.xx
Init HTTPS stack...OK
Connecting...OK
Sending request...OK
Receiving...OK
-----HTTP RESPONSE-----
http/1.1 200 ok
server: nginx/1.14.0 (ubuntu)
date: thu, 27 may 2021 17:55:28 gmt
content-length: 47
connection: keep-alive
expires: fri, 28 may 2021 17:55:28 gmt
cache-control: max-age=86400
{"date":210527,"time":175528,"tick":2935458400}
Waiting 5 seconds...
Receiving...OK
http/1.1 200 ok
date: thu, 27 may 2021 17:55:34 gmt
content-length: 47
expires: fri, 28 may 2021 17:55:34 gmt
<SNIP>
Any debug options to try possible?
TeamPlus
Post by TeamPlus »
Hi
We have had similar problems with the Team Plus software for the One+ model B. What I have found is that the SIM service provider is not always providing an IPv4 address for the SIM network, often only providing an IPv6 address.
Then the tcp ip libraries are not able to connect to servers without a IPv6 address and that includes both the freematics and team plus versions of hub servers.
I am working through this more over the next few days to see if I can nail down how to resolve this.
Cheers
Shaun. - Team Plus IT.
