Question about HTTPS support Freematics ONE+ Model B
ipindado
Post by ipindado »
Hi...
I've recently started to develop with a Freematics ONE+ Model B and Freematics OBD-II Emulator.
I have started with telelogger sketch and I was able to build the project and to upload it to the device, start monitor, etc, but for some reason I am not able to send data to the server.
I've tried both GET and POST methods with our testbed which is running on cloud over HTTPS...
I changed config settings to match our server configuration (host, method,...) and updated the client to match the server path, but I am getting a
"No HTTP Response error"
Is it HTTPS protocol supported? Is it required to perform some kind of additional settings?
CPU:160MHz FLASH:16MB
IRAM:342KB
DEVICE ID:UCFLVA28
TYPE:14
MEMS:ICM-42627
ACC BIAS:-0.17/-0.07/-0.97
GNSS:OK
OBD:NO
[ 10335][E][sd_diskio.cpp:802] sdcard_mount(): f_mount failed: (13) There is no valid FAT volume
NO SD CARD
[CELL] Activating...
CELL:SIM7070G
IMEI:65456053720601
[CELL] Searching...
APN:orangeworld
Operator:simyo
[CELL] IP:10.46.70.34
LOGIN(xxx.xxx.xxx:443)...
[CELL] In service
RSSI:-81dBm
0:18982,24:374,20:0;0;0,82:45*E7
[BUF] 13 samples | 128 bytes | 4/32
No HTTP response
[BUF] 66 samples | 648 bytes | 20/32
CELL:SIM7070G
IMEI:65456053720601
[CELL] Searching...
APN:orangeworld
Operator:simyo
[CELL] IP:10.53.112.41
[CELL] In service
RSSI:-81dBm
0:16982,24:380,20:-0.41;0.69;-0.22,82:45*FE
No HTTP response
Timeouts: OBD:0 Network:1
0:25631,24:380,20:-0.18;0.06;-0.39,82:45*F8
[BUF] 16 samples | 158 bytes | 5/32
No HTTP response
Timeouts: OBD:0 Network:2
[BUF] 22 samples | 218 bytes | 7/32
RSSI:-79dBm
0:34280,24:374,20:-0.55;0.57;-0.31,82:45*FA
[BUF] 26 samples | 256 bytes | 8/32
Thanks and best regards.
ipindado
Re: Question about HTTPS support Freematics ONE+ Model B
Post by ipindado »
I reply myself...
So considering the telelogger demo it seems that although the config supports HTTPS configuration, when setting the protocol and the port, the actual library FreematicsNetwork.cpp does not initialize correctly the SIM7070 component when opening the connection.... It sends a regular HTTP request to the HTTPS port...
Just for the records, this works for me...
Here....
bool CellHTTP::open(const char* host, uint16_t port)
  if (m_type == CELL_SIM7070) {
    sendCommand("AT+CNACT=0,1\r");
    sendCommand("AT+CACID=0\r");
    sprintf(m_buffer, "AT+SHCONF=\"URL\",\"http://%s:%u\"\r", host, port);
    if (!sendCommand(m_buffer)) {
      return false;
    sendCommand("AT+SHCONF=\"HEADERLEN\",256\r");
    sendCommand("AT+SHCONF=\"BODYLEN\",1024\r");
    sendCommand("AT+SHCONN\r", HTTP_CONN_TIMEOUT);
I updated the code for the SSL initialization of the SIM7070 module.
    const char *protocol = (port == 443) ? "https" : "http"; // Technically it can be other port number so another param should be required in the method for the protocol
    if (port == 443) {
      sendCommand("AT+SHSSL=1,\"\"\r");    // This setting makes the client to trust in the server certificate
      sendCommand("AT+CSSLCFG=\"ignorertctime\",1,1\r");
      sendCommand("AT+CSSLCFG=\"SSLVERSION\",1,3\r");
      char comandSNI[100];
      sprintf(comandSNI, "AT+CSSLCFG=\"sni\",1,\"%s\"\r", host);
      sendCommand(comandSNI);
    sprintf(m_buffer, "AT+SHCONF=\"URL\",\"%s://%s:%d\"\r", protocol, host, port); // URL should include the protocol based on the settings
I made it dependant of the port number just for testing purposes, but it can be improved...
I took as reference: https://gist.github.com/baconcheese113/ ... 6fa031aed2 for the modem initialization.
Best regards..
Thanks for sharing this. I will include this code snippet in the code base if you don't mind.
ipindado
Post by ipindado »
sure...
cuhnkedrik
Post by cuhnkedrik »
Your contribution is greatly appreciated. With your permission, I'd like to add this line of code to the repository.
