Emulator command set: DTC7/DTCA not working
Alex4WAG
Post by Alex4WAG »
Hi There,
I have a problem with the emulator command set:
"ATSET DTC=P0105,P0106" is working fine and quitted with "OK"
"ATSET DTC7=P0105,P0106" and "ATSET DTCA=P0105,P0106" ist quitted with "ERROR".
Can somebody help?
Regards,
Alex.
Re: Emulator command set: DTC7/DTCA not working
Your emulator must have J1850 support to work with mode 7 and mode A.
Alex4WAG
Post by Alex4WAG »
Thanks, I am afraid mine does not. With J1850, will it support mode 07 and 0a with CAN protocol, too?
Is there any way to update my device?
Which J1850 protocol do I have to order to get mode 07 and mode 0a running with CAN?
They are different hardware and not upgradable by software.
nitionic
Post by nitionic »
Hi all, same question here, I am unable to set a pending DTC (mode 07), the button in the GUI is greyed out, and when trying it through the serial port I also receive 'ERROR’. Mode 03 DTC’s work fine. The emulator does have J1850 mentioned on the connector. Any clues? Would be great to get this working.
Alex4WAG
Post by Alex4WAG »
Thanks, but which J1850 protocol do I have to order to get mode 07 and mode 0a running with CAN?
Yes you can.
Alex4WAG
Post by Alex4WAG »
You are offering two options: J1850 PWM and J1850 VPW. Which one do I need to get mode 07 and mode 0a running with the serial commands?
Both will do.
