New Function For Requests With Headers (Custom PIDs)
Posted: Wed Feb 28, 2024 8:47 am
by extremerotary
I created a new function in the OBD2UART.cpp file. Stanley, can you verify that my format is correct? I believe it needs to be 'header' # 'dataMode' 'pid'. The intention is then to be able to request custom manufacturer-specific PIDs that require a header. Do you believe this will function as desired? I know you have a function to set the header via the FreematicsOBD.cpp, but since this is a different chipset with different firmware, I just want to verify that I'm on the right track and there isn't any compatibility issues with the firmware that's loaded on the OBD2UART chip. Thanks for your time!
bool COBD::readPidWithHeader(byte pid, byte header, byte dataMode, int& result)
	char buffer[64];
	char* data = 0;
	sprintf(buffer, "%02X#%02X%02X\r", header, dataMode, pid);
	write(buffer);
	Serial.println(buffer);
	idleTasks();
	if (receive(buffer, sizeof(buffer)) > 0) {
		char *p = buffer;
		while ((p = strstr(p, "41 "))) {
			p += 3;
			byte curpid = hex2uint8(p);
			if (curpid == pid) {
				errors = 0;
				while (*p && *p != ' ') p++;
				while (*p == ' ') p++;
				if (*p) {
					data = p;
					break;
	if (!data) {
		errors++;
		result = -9999;
		return false; //was return false
		//checkErrorMessage(buffer);  // This didn't used to be here. Trying to get the error message
	result = normalizeData(pid, data);
	return true;
