No PID Display
DonJuan
No PID Display
Post by DonJuan »
Hello sir,
I working on my suzuki swift,first i upload the example code for i2c obd but when i hit the rpm above 3000 the led still turn off. Then i try to check for the adapter connection first :
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
COBDI2C obd;
void setup()
pinMode(13, OUTPUT);
obd.begin();
while (!obd.init());
digitalWrite(13,HIGH);
void loop()
// int value;
//if (obd.read(PID_CONTROL_MODULE_VOLTAGE, value)) {
//digitalWrite(13,HIGH);
// digitalWrite(13, value > 3000 ? HIGH : LOW);
When i turn on the engine, the LED starts blinking. Then i try to get the RPM but still nothing happen.
Any info for reading the parameter? Should program the adapter again? (i'm using freematics adapter model B)
Re: No PID Display
Please check if read() returns true or false.
